RCU Forums
-   Tips & Techniques (https://www.rcuniverse.com/forum/tips-techniques-180/)
-   -   Lightest tissue covering method (https://www.rcuniverse.com/forum/tips-techniques-180/9466193-lightest-tissue-covering-method.html)
Malgera 02-01-2010 05:37 AM
Hi,
I've got a little sterling SE5A I am going to convert over to rc, I've been thinking about how I'm going to build it for the last few days, while already doing too many projects.....These planes take up too much of my attention........Anyway!
I want to use the supplied coloured tissue, but what is the best way to cover the frames without adding too much weight?
I have covered a few models in tissue and dope, but they were larger models. The dope did add a bit of weight to those models, but it did not matter as much.
Any help would be appreciated!
stevenmax50 02-01-2010 12:55 PM
RE: Lightest tissue covering method
I have never covered with tissue but I do use Sig Koverall fabric.  Instead of dope I use Minwax Polycrilic.  It is water based and very light as all the water evaporates when it dries.  It dries in less than 30 minutes and it takes about 6 coats (sanding between each coat after coat #3).  You do have to paint the model as the Koverall is white and the poly is translucent.  I dont know if this method will work for what you are trying to accomplish but it may be worth looking into.
Lnewqban 02-01-2010 01:00 PM
Malgera,
At this excellent site, you can find several articles related to tissue covering:
http://pensacolafreeflight.org/pageD...p?pageid=13152
Instead of dope, these champs have been using a lighter alternative:
http://www.tpbweb.com/media/catalog/253.pdf
Regards!
John 38 02-02-2010 04:39 AM
If you want to stay with dope - use plenty of thinners - at least 50% .
I use 50/50 on polyester material so tissue should be ok with even more - experiment
keep surfaces vertical when painting on - any dope soaking thru will go to the structure and not form drips in the middle of panels
hope this helps
john
j.duncker 02-03-2010 03:39 PM
The UK FF boys have gone for tissue over mylar. I tried it on an indoor model and it is easy to do.
here is a how to site [link=http://www.gryffinaero.com/models/ffpages/tips/mylartissue.html]clicky[/link]
