RCU Forums
-   Tips & Techniques (https://www.rcuniverse.com/forum/tips-techniques-180/)
-   -   Replacing Hinges (https://www.rcuniverse.com/forum/tips-techniques-180/949905-replacing-hinges.html)
Bruce Rolfe 07-12-2003 01:50 AM
Replacing Hinges
I need a little help from you experts. I got a ARF from a guy who couldn't put a plane together if he tried. I am in the process of replacing all the hinges. Unfortunately when I took out the old hinges it left a gaping hole in the LE Of the Elevator and Rudder. What is the best stuff to use to fill in these gaps. I will need to use some of the old holes for the new hinges.
Any help would be greatly appreciated.
Thanks, Bruce.
Highlander 07-12-2003 06:33 AM
Replacing Hinges
If you cant move them to new spots ,? (best method ) but keep in mind that CA works by capilary action meaning that it must be absorbed by the wood , the old holes will already be sealed from the first time they were glued ,this will cause a weak hinge !!!
what kind of plane is it , trainer ? sport ,aerobatic?
the problem becomes more servere the faster and manuverable the plane is ,
so depending on the plane , either move the hinges or fill the holes with epoxy and use pinned hinges they are thicker and need a larger slot to fit , once installed use tooth picks and pin them thru the TE while the epoxy is still cureing. one pin per hinge is the norm .
Highlander
