Go Back  RCU Forums > RC Airplanes > RC Jets > Turbine Clinic > TJT Turbine Direct Support
 starter coool down problem >
TJT Turbine Direct Support Ask your questions about TJT turbine in this forum. All I-Jets related questions may be asked here if relevant or in the general jet forum.
Old 09-18-2009 | 10:54 AM
Default starter coool down problem
Hello,
I am a happy owner of an Artes/TJT 3000 with more than 100 fligth.
I have a problem with the starter motor during the cool down sequence.
A strange sound (like the starter is less power) and the cool down
sequence need more time to complete than before and, the noise sound continue.
Maybe the battery is loosing is life time? or someting else?
Tkanks in advace,
Roberto Castellan from Italy, Ciao.
Old 09-18-2009 | 06:00 PM
FILE IFR 's Avatar
Default RE: starter coool down problem
I'm not an Artes guy, but my first thought is a worn-out 'O' ring at the starter's cup.
Old 11-20-2009 | 07:31 PM
I Agree with FILE IFR , The first thing I would investigate is the O-ring in the starter cup. The motor in the starters dont run long enough to get worn quick unless it stayes hooked to the compressor and runs with the engine which then turns it to a generator ..
Old 11-21-2009 | 12:11 AM
Wayne22's Avatar
pull the motor out of the starter bullet, and apply some power to it...if it still vibrates and makes noise, is likely the bearings are shot (it happens), if it is quiet, likely the o ring as suggested above....
