Rad. Shack servo help?
First of all i am so so sooooo glad i found this forum, second of all (getting back onto topic) i have a radioshack f350 4x4 that i baught about 3 years back, it has run very nicely and survived my abuses but now that the electronics board is broken (due to water form my winter bashings) i have upraded it to hobby class however i dont know how to fit the servo into place, it will fit up the stock servo slot but gets stuck on a little lump. I was thinking of just cutting the whole front of the truck off but i decided to get some advice before i do anything. Help would be greatly appreciated and pics to thanks.
-Rock Blazer
-Rock Blazer
RE: Rad. Shack servo help?
HELLO ..rock_blazer [8D]
See this thread, it can perhaps help you .. Give us pics of your F-350.
http://www.rcuniverse.com/forum/m_8922769/tm.htm
Ok here are some pics that i have of the truck and also some flex shots before and after. ALong with a pic of where the bump is in the slot along with were i planned to cut off but i am waiting on advice.
BEFOREARCTICULATIONPICS
AFTERSOMEMINORSHOCK/ SUSPENSIONMODS (surprisingly a bit more than normal)
Take note that tha the matress is about 3X the height of my fist in the pic
Thank for the pics .. [sm=thumbup.gif]
If you cut the plastic, do it .. but leave some parts .. for the installation of your new servo HG.[8D]
So do you think i should grind the stub off or cut the front end off? I noticed in the first pic that right side is a bit cricked too, would that happen if i put my servo into the slot and hooked it up?
Try installing it between two walls of plastic ..
Put your servo into the slot ..
It should fit in place of the old servo ..
Before you cut too much, try it in this eapace time to time ..[8D]
Ok well ill try to grind that stub off, maybe with a dremel or soomething but if it gets too complicated ill just cut the end off. thanks for the help, by the way what does eapace mean (easy pace?) well ill send some feedback on how weel it goes
