RE: (SILVER-SCORPION) New Bright Rock Crawler
1 Attachment(s)
SOME PICS FROM TEST DRIVE..
nbcrawler ..
Your crawler has a very good flex .. Now, you must change your motors, and perhaps install a 4th gear ?[8D] http://i346.photobucket.com/albums/p...outex/sup3.jpg |
JUST GOT A NEW BODY TODAY..
ITS A 1/6 NEWBRIGHT EXCALADE.. GUNNA TRY TO CUT IT TO FIT THE 1/10 CHASSIS AND MAKE IT LOOK LIKE A SCALE CRAWLER.. ALSO GOT A 280 MOTOR.. STILL WAITING ON ANOTHER ONE.. PICS WITH BODY ON SOON.. |
nbcrawler ..
Good luck for the installation of your new body .. and also for your 280 missing [sm=thumbup.gif] |
Could someone tell me what pitch has to do with describing a pinion? Also, what size is the shaft of the motor on the stock NB rockcrawler motors? I am looking on ebay for 8 tooth pinions and they all have different pitch and shaft size. What pitch and size should I be looking to get for my new bright?;)
I advise you to go to the hobby store, with your motor and pinion 10 tooth ..
....... and ask that you find two 8 tooth pinion .. If you have with you ,the two 4 th gear, they will find two 8-tooth pinion, which mate with the two 4 th gears .. ################################################## ############# You can also just make the installation of two 8 tooth pinions, they will give more strength to your crawler .. ################################################## ############### I was very lucky to find this war tank used ($ 6.00), with two 34x10 and two motor 280. :D I do not recall if the two 8 tooth pinions, came from that war-tank .. [:o] |
made some more cuts and made a bracket to reinforce my front end.. here it is..
http://i36.tinypic.com/2pqs761.jpg |
WOW[:-] That is some impressive articulation! Very nice work</p> |
YES .. Great flex .. [sm=thumbup.gif]
hi, i want to get a new body for my nb.. but i dont know which one to get..
pickup? like toyota/ford/chevy/etc..? suv? bronco/blazer/etc..? or any rockcrawler looking body..? i also need help finding a website that sells either bodys.. soo let me know what wesites are good for buying new bodys.. thanks! |
You can find bodies at most any hobby shop.
I usually get mine cheap from thrift stores,flea market,& yard sales :) I have a few bodies not being used.....what exactly are you looking for??? |
something like the duratrax cliff climber rock crawler style.. something like that..
MORE PICS..
BEFORE.. http://i34.tinypic.com/51emw3.jpg AFTER.. http://i36.tinypic.com/144k8k.jpg http://i33.tinypic.com/15ezqr8.jpg SUSPENSION MOD.. TEST FITTING.. http://i36.tinypic.com/2v8fka9.jpg LONGER PINS.. ABOUT 3IN LONG.. http://i34.tinypic.com/j5ig55.jpg |
1 Attachment(s)
ordering these! http://www.rcuniverse.com/forum/js/f...eeth_smile.gif
WOW ..[X(] Good (( flex ))
These tires make all the difference .. [sm=thumbup.gif] Good buy ..;) |
thanks texx
1 Attachment(s)
CUT THE GRILL.. MORE MODS COMING SOON
This small addition, it gives a very good look ..
It begins to resemble YELLOW-CRAWLER ..:D Just an idea .. Keep up the good work ..[sm=thumbup.gif] http://i346.photobucket.com/albums/p...loutex/AA1.jpg |
thanks.
how did you make the hard top for the yellow crawler? and what did you use to take the stickers off? i used goof off and it started to remove the paint also... |
HERES AN UPDATE..
THINKING ABOUT PAINTING IT. ANY SUGGESTIONS? HERE IT IS. http://i36.tinypic.com/2ylmg54.jpg |
ORIGINAL: nbcrawler thanks. how did you make the hard top for the yellow crawler? and what did you use to take the stickers off? i used goof off and it started to remove the paint also... On YELLOW-CRAWLER, everything that appears on the yellow paint has been painted with a small brush .. http://i346.photobucket.com/albums/p...7220143710.jpg For the hard top, I lowered the windshield, and I built the hard top, with plastic (DVD COVER) .. :D http://i346.photobucket.com/albums/p...16104885-2.jpg http://i346.photobucket.com/albums/p...titledxs-1.jpg The roll cage inside, is made with thick, plastic hangers .. [sm=thumbup.gif] When I need a sticker, I cut from magazines, and I stick with glue made for plastic (below and above) ....;) http://i346.photobucket.com/albums/p...uloutex/52.jpg ...or, I stick to real sticker ..:D My crawler BLACK FLY .. before YELLOW-CRAWLER ... http://i346.photobucket.com/albums/p...outex/sky3.jpg |
ORIGINAL: nbcrawler HERES AN UPDATE.. THINKING ABOUT PAINTING IT. ANY SUGGESTIONS? HERE IT IS. http://i36.tinypic.com/2ylmg54.jpg ((((( GGGRREAT CCCRRRAAWLER ))))))[X(][X(] |
thanks texx. im going to try to make a hardtop tomorrow.
Good luck .. for the cab .. :D
hey nbcrawler what kind of electronics did you use and were did u get them.</p> |
