Traxxas Summit
#627
AL
RE: Traxxas Summit
Wow! Its like night and day between nimh and lipo! Had fun for about and hour then my motor overheated bc its sooo fn hot out! I think i fried it. It only goes forward now. Might take it out tomorrow and finish it off. Lol ive been wanting the dewalt drill motor for awhile now anyway.
#628
MI
RE: Traxxas Summit
ORIGINAL: JUCD VPR
There is no way i'm putting dirty danglers on my trucks. I don;t like to stare at balls, but to each their own I guess lol
Hey, I'm just kidding, to each thier own. I guess it says your truck is a full blooded MALE, but I don't like 'em.
OMG, see? The commonly accepted slang for breasts is edited out, but not balls, how about nuts? or cahones? lol
#629
Banned
RE: Traxxas Summit
A ball is something you bounce and nut is commonly used in conjunction with a bolt.
Hey Beast post up some pics of your Dewalt conversion. Are you going to get one from kershaw or are you going to cut off the pinion and do the soldering yourself? Glad you're enjoying your lipos, did you kill the stock motor completely yet?
#634
AL
RE: Traxxas Summit
The titan did finish itself off today...didnt get a vid but there was alittle smoke. Cut it off b4 it could burn anything. It was smoking hot!!!!
I have this drill motor that bolts right up to the motor mount so im going to use it for awhile.
#637
RE: Traxxas Summit
OK I get to join the Summit crew now. I am gona go pick it up tomarow. I was gona go get it tonight but I have to drive 60 miles to the hobby store to get it and it is storming bad rite now between here and there. For the time being it will be stock but I see Lipos in the future. How long will it run 100% stock with the 2 3200MAH batteries? What is the top speed? I just hope I get to paly with it once in a while. I have a feeling my 4 year old son will get more wheel time than me. He is realy good with his Dominuse SC10. What Lipos are good for a stock truck? I am going to be more concerned with more run time than more power. More power/speed is great but not my main goal with going to LIPOs.
#638
AL
RE: Traxxas Summit
Welcome to the club. It runs around 30-45 min with the stock nimhs. Its top speed is 20mph. I just got lipos if u look back a page or two it shows the website. They were $50 a piece...only got to run them once bc my titan 775 burnt out yesterday. But from the hour i got to drive with the lipos was wonderful. 10x better than the nimh stock batts. Good luck sleeping tonight. I slept about an hour or two xmas eve!!! Lmao
#639
AL
RE: Traxxas Summit
Nice pics btw jdog. I ran across this vid on utube. Its the motor im putting in til i get a new 1. Thanks to jdog i had it layin around! Lol
#640
VA
RE: Traxxas Summit
ORIGINAL: B_Krukow
The Summit forum over at Traxxas.com also has a lot of helpful information. The E-Revo &Summit Forum over at URCis also pretty good.
One thing you will need to verify about your Summit when you buy it: is it one of the new Summits that has the LVD enabled ESC? In other words, is it a new Summit with Low Voltage Detection? If it is, great, all you need to buy are LiPos and a charger. If it is one of the older Summits, it will not have LVD built in. That's not a problem, all you need to do is buy 3-4 of these cheap Low Voltage Alarms from ebay. The easy way to know is the box should have something on the outside that says "Now with Low Voltage Detection" or something like that. If it doesn't, then it's probably an older model.
As far as LiPos go, I would strongly recommend these 8200 mAh batteries from SPCracing. I get 2+ hours of run time in my Summit in low gear. These are fantastic batteries, and most of the regulars on the Summit forum at Traxxas swear by them.
#641
RE: Traxxas Summit
Thanks. Got it home tonight and ran the first set of batteries threw it. I was a little disapointed .The 2 stock batteries only lasted 10 ish minutes. My boy was running it in low range and when I finaly convinsed him to let me play a little they where dang near dead. When I stabbed the throtle in high the lights would shut off and take a bit to come back on. I asume this is normal when the batteries are dying. I have a few isues to figure out but nothing a little fideling cant fix. The stearing trim is off or the alignment is off cause it realy likes to drift off to one side while driving in a straight line. You have to actualy stear to the oposite side to drive straight. the knob on the side of the controler that says stearing trim dosent seem to do anything.
#642
AL
RE: Traxxas Summit
Hmmm ive never had any probs with my steering. I cant believe the batts lasted 10 min. My first few runs mine lasted around 45 min. After i ran them 10-15 times they last about 30.
#643
VA
RE: Traxxas Summit
It sounds like you bought one used?
Not at all unusual for the stock NiMh batteries to have short run times if they are old. If the batteries have been used enough they will have a very diminished capacity.
You should be able to adjust your steering as well. If the steering trim isn't working at all, then return it to center on the remote. Then turn on your truck with the wheels off the ground. (Coffee can, shoe box, etc) the servos will center, and you can adjust the toe links/turnbuckles to get the tires lined up properly. I've found that mine tends to track a little better if the front tires have a slight toe out, and the rear tires have a slight toe in.
Invest in some LiPos and a Low Voltage Alarm, rather than buying more NiMh batteries. You'll be very happy with the increase in run time.
#644
AL
RE: Traxxas Summit
So this B&D drill motor i have doesnt have the capacitors...i think thats what those little brownish looking balls hooked up to the titan at the end of the wires that go to the motor are called. Anyways what would happen if i wire it up without those bc i threw them in the trash! Lol
#646
AL
RE: Traxxas Summit
The drill motor i have didnt come with them but i threw the 1s from the titan away. Didnt know if i needed to add them to this drill motor i have. But it wont go up in flames without them right?
#647
RE: Traxxas Summit
The truck is brand new. It has teh LVD built in so I can just get some good LIPOs and go. I figured out the drifting isue. For some reason last nite when I ran it the stearing trim did nothing but today it straightened it out. The batteries are still only lasting 15 ish minutes though. I am begining to wonder if I am not getting them fully charged. It only takes abought 35 minutes to charge them to what the charger says is full at a 3 amp charge rate.
#648
AL
RE: Traxxas Summit
Yeah they arent charging all the way for whatever reason. When I charge mine at 3 amps it takes that batt over an hour to fully charge.
#649
VA
RE: Traxxas Summit
15-20 minutes is about all you're going to get out of the stock 3000 mAh NiMhs. And that is pretty dependent on what you are doing, too.
A good pair of 6000-8200 mAh LiPos will solve that problem for you.
#650
RE: Traxxas Summit
Well last nite they charged for rite at an hour each and then it ran a lot longer than the first two times. The charger said it put rite around 2700Mah into each one so aperently something was a little off the first two charges. Now I just need to convinse teh wife to let me spend a little more and get the good batteries. She is already in disbalife of what i paid for this toy. I may end up owing her a date or twobefore this is all said and done.
