Traxxas Summit
#53
Banned
RE: Traxxas Summit
Big Joes look good but they are really heavy and the rims they are on don't have an offset like the summit rims so they sit pretty close to the body. I probably wouldn't buy them again... Every time I have used them on my E-Revo I have broken something, cartwheels with the Big Joes don't end to well. They sure look good though. [&:]
#54
NY
RE: Traxxas Summit
See kennu i think that the big joes and perfect for the Summit because of there wide stance and good traction. Plus I don't think your going to break anything on the summit with those
#55
Banned
RE: Traxxas Summit
Yeah you're probably right, the summit doesn't really cartwheel. I would like them on a rim with some offset though and some better servos wouldn't hurt.
#57
Banned
RE: Traxxas Summit
ORIGINAL: pyromatic177
i would get 2 of those hitecs for your summit
#58
AL
RE: Traxxas Summit
Ok so ive done about 10 runs on my summit and the manual says to clean and lube the titan 775 every 10-15 runs. It doesnt say exactly what to use tho. IYO what is the best cleaner and lube or oil for this motor?
#59
VA
RE: Traxxas Summit
For cleaning, you can get a can of CRC Lectra Motive from AutoZone for $6. Spray the motor inside and out until the spray is running clean out of the motor.
For lubricating, 3 in 1 oil on the motor shaft at the bearing is all you need. Don't oil the brushes.
#60
VA
RE: Traxxas Summit
ORIGINAL: Dale Gribble
Just keep in mind that with more weight comes more problems when you slap on some big ole wheels and tires like that. If I am running a basher, I usually like a lighter weight solution. I put this pic in my thread, but I am running wheels/tires from a Savage Flux. They are a little shorter and more narrow than the stockers. They are also lighter.
In this case, the Summit is definitely the exception (as it so often is) for a couple of reasons. The Trencher X's are the same size and almost the same weight (slightly heavier, but not that much) as the stock canyons. If you're planning on using this truck the way it was intended, you want more mass in the wheels to keep it firmly planted.
Plus the Summit shafts are a good deal beefier than the stock Revo shafts, so they will handle the extra weight better.
But, given that you are converting yours more into a Revo basher, I would say your wheel/tire setup is a reasonable setup.
#61
AL
RE: Traxxas Summit
Thanks im going to clean it tomorrow. Im kinda scared to take the motor out for the first time..lol..i hope its easy and goes back in right!!!
#63
AL
RE: Traxxas Summit
Whats the best way to get water out of the tires. Just took my tires off and realized they weigh like a pound a piece!!!! That explains why it was turning slower last time out. I squeezed them over the sink and alot came out but theres still more in there!
#64
Banned
RE: Traxxas Summit
You can put a small hole in the tire and the water will shoot out while your driving or just keep squeezing them. I got a lot of water in my tires last time out and I have been letting the tire sit upright for a few hours with one of the holes in the rim at the bottom so all the water drains down and then giving it a good squeeze.
Taking the motor off is easy enough, when your putting it back on make sure you set the gear mesh between the spur and pinion gears correctly. check out page 25 of your manual for adjusting the gear mesh.
#66
VA
RE: Traxxas Summit
ORIGINAL: Summit is Beast!!!
The motor comes out very easily. Remove the top screw that sets the gear mesh, the slowly back the motor off of the bottom hinge mount. Nothing to it.
#67
NY
RE: Traxxas Summit
but did you get a new body for your summit already? i thought you had a solid red lid
#68
RE: Traxxas Summit
I will be brushless next week and I'll let you know.
#69
VA
RE: Traxxas Summit
ORIGINAL: CustomSummit
What brushless sytem did you end up going with?Are you running the aluminum diff carriers as well, or trying stock first?I am curious to see how aluminum diff cups holds up to brushless.
#70
RE: Traxxas Summit
Thanks for the tip, Iam a member over there, I was one of the ones to order 10 of them, 6 to keep and 4 to sell off,I figured a few more people would appreciate the discount buying 10 brings on only 2, since they are pretty unaffordable otherwise. I have not yet had a chance to install my own, so am always curious to see other opinions while Iwait, seems like not to many people are running them as of yet.
ORIGINAL: LaTuFu
You might want to search on the Summit forum on Traxxas.com. There is a member there who has a company in Germany manufacturing custom aluminum diff cups. According to him and a couple of the guys that have purchased a set from him, they have not blown a diff since they put them in. They've been pretty pleased with the improvement so far. They're pretty pricey, though.
#72
NY
RE: Traxxas Summit
