Help! Throttle won't go wot with flysky gt3b.
NL, CANADA
hey all. i have 2.5 revo with a 3.3 in it. i just bought a flysky gt3b and installed it. i setup the optidrive everything works how it should but i can't get the throttle to open all the way. so far i have:
-adjusted the arm on the servo
-adjusted the arm on the end of the carb slide(there was a fair bit of play)
seems like the servo strains before it gets to the wot position. i go wot and after a few seconda i can watch the servo turn back a little. could my battery pack be weak?
should i buy a new servo and try? maybe an integy mix arm would do the trick?
i am not sure what to do here. it seemed fine with the old am radio. maybe i should reinstall it and see what happens. oh if i turn the trim all the way back i can get it to open almost all the way. but then i have no adjustment if it idles a little to high.
thoughts and suggestions welcome.
thanks all!
thanks all!
