1/16TH E-REVO
Banned
RE: 1/16TH E-REVO
i think im goping to get it. its the brushless (VXL) model. but he doesnt have any lipo batteries. what kind of batteries and charger should i buy? and how long before the batteries die and need to recharge again??
NY
RE: 1/16TH E-REVO
Um it depends on what MAH you get for them, I suggest these batteriesspcracing.com/index.phpAnd this chargerwww.hobbypartz.com/thac6smbachw.htmland you'll need this charger adapterwww3.towerhobbies.com/cgi-bin/wti0001p
RE: 1/16TH E-REVO
wow why did i think batteries were going to be like $40 each?!?!
so would i run one battery at a time or would i get that connector and run 2 at a time?
and how long for each run? like 20-30 mins?
RE: 1/16TH E-REVO
ok alot of good reviews on there batteries here:
http://www.hobbyking.com/hobbyking/s...00mAh_2S1P_40C
and they are like $9
should i get those?!?
and would i run one battery or 2 at a time?
would i get better run time doing 2 at a time?
also what are come good upgrades? should i get some kind of fan to keep the heat down?
Moderator
RE: 1/16TH E-REVO
Get those batteries, but get this connector to solder on to it; http://www.amainhobbies.com/product_...et-Male-Female . Solder on the one that is not on your esc. Do not run 2 LiPO Batteries at a time with the stock ESC, the voltage would be too high and you would burn up the ESC once you plug them in. 1 LiPO is great. One good upgrade is some denser shock springs.
RE: 1/16TH E-REVO
SO this charger:
http://www.hobbypartz.com/thac6smbachw.html
these batteries:
these connectors:
another question:
Will my DX2s controller/reciver work with the 1/16 revo?
these batteries:
these connectors:
another question:
NY
RE: 1/16TH E-REVO
Sure that's a good combo! But yeah you run this plug www.amainhobbies.com/product_info.php/cPath/1_25_1466_1231/products_id/141619/n/Traxxas-Parallel-Battery-Wire-Harnessfor the lipo's it'll last like 35 min i beileve with the 2. Because it uses the MAH of the 2 with the voltage of the one!
RE: 1/16TH E-REVO
just made an order:
push rods
toe links
LIPO charger
Rpm rear arms
RPM front rms
New front body mount assembly
Ordering 4 Lipos and the connecters maybe today need to figure out how much money i have.......
Slipstream body, wheels and wing coming soon
push rods
toe links
LIPO charger
Rpm rear arms
RPM front rms
RE: 1/16TH E-REVO
ORIGINAL: pyromatic177
Make sure the ESC is in Lipo mode. Which is either a solid red or green light. Look in your mannual
