Traxxas Monster Truck forum Discuss the Traxxas T-Maxx, E-Maxx, Super-Maxx and all other Traxxas monster trucks in this forum. You may also optionally discuss them in our MT general discussion forum.
Help ID this tmaxx
Old 08-13-2012, 12:40 PM
SatisTraction
Default Help ID this tmaxx
I bought this truck this weekend and would like to get it back going. The tranny is messed up and i have no charger for the truck or the ez start charger.
I know there are several models and that the tranny may not swap between them. The engine is the 3.3 and body says 3.3 but who knows if they are original. the tranny may not even be original. the truck has some up grades as you can tell.
any info would be helpful.
thanks
ID:	1791630   Click image for larger version
ID:	1791631   Click image for larger version
ID:	1791632   Click image for larger version
ID:	1791633   Click image for larger version
ID:	1791634   Click image for larger version
ID:	1791635   Click image for larger version
Old 08-13-2012, 01:51 PM
The_Shark
The_Shark's Avatar
Default RE: Help ID this tmaxx
gen 3.
original had a .15 narrow suspension small drive shafts
gen 2 had a 2.5, wider suspension stronger bulheads
gen 3 had 2.5r and 3.3, new optidrive transmission, updated driveshafts, different tires and shock towers.
gen 4 3.3 has reverse removed.
yours has upgraded driveshafts from what I can see.
Old 08-14-2012, 04:06 AM
SatisTraction
Thanks.
what model number would that be? 4909?
can i put a gen 4 tranny in or would i need to stay with the gen 3?
Old 08-16-2012, 01:36 PM
Snook Man
Snook Man's Avatar
Your truck appears to be the 4909 model.
You can fit the 4908/7 transmission in it but the output shaft is 6mm instead of 5mm like yours.
You will have to adapt the center shafts to fit the output shaft.
Yours truck appears to have the Forward only converion, if so you can install that output shaft in the 4908/7 transmission and the center shafts will be a direct fit.
Old 08-20-2012, 03:29 PM
SatisTraction
i took the tranny apart and it has one stripped gear on the inside. It is a forward only tranny. Now i just have to figure out what part to order;
Old 10-07-2012, 10:50 AM
Quickywd01
Quickywd01's Avatar
http://traxxas.com/explodedviews/490...View-T-Maxx-33
http://traxxas.com/products/models/n...xx33-downloads
Old 01-28-2013, 02:21 PM
SatisTraction
ORIGINAL: Snook Man
the
Back from the dead!!
i started looking into this today and want to get it back going. After looking at all the exploded tranny drawings i do think that this is the 4909 tranny. the 5395 gear is stripped. for the price of the gear and shipping i would rather buy a new 4909 tranny and have some "spare" parts. the problem is that i do not see any 4909 trannys for sale. where can i buy one?
why do you think it has a forward on conversion? i can post up some internal pics if it will help id what i have here. in teh 2nd pic you see the stripped gear.
Old 01-28-2013, 02:42 PM
SatisTraction
this still has reverse.
i think i will buy
5195 forward only
5395 output gears
3982 (missing a washer)
anything else while i am in there?
