platinum tranny work?
blew out the tranny in my 2.5 framed revo today, will the platinum edition tranny work in it? i know the 3.3 tranny will work no problem, just cant tell from pics if the platinum tranny is the same as regular tranny. i know the platinum tranny is forward only. dont know if it has the same case or not. asking cuz i have access to a platinum tranny. thanks
RE: platinum tranny work?
Sure is, they are both the same housing, only thing is yep it's forward only but it has a centre diff with rear brakes.
From memory, don't quote me but I don't thing there is enough room for the rear brakes, I think there are some guides out there on grinding the chassis slightly to make it fit. Allso u can get the revo Platnium throttle servo and reciver boxes for a bit more weight saving
ATM Ive got 2 gearboxes in my Platnium, stock Platnium one, and one with reverse. To be honest I use the one with reverse more...
Check these guys out, they have a good name and make a few toddies for the revo
http://www.robinsonracing.com/traxxas.html
All the parts u can buy sepperat, they have forward only kits, reverse kits, locked centre diff kits, close ratio gear sets, wide ratio gear sets, etc
ORIGINAL: phmaximus
thanks for the replys. ended up ordering a slayer tranny an a FOC kit for the gears. was a touch cheaper that way then buying a new revo tranny and FOC kit. platinum tranny was toast that i got
