T-Maxx take off problem. I'm new to nitro
Ok so i took my truck out today , an noticed when i go to take off it kinda boggs an will die.
But if i play with the throttle abit i can save it an it will run fine. Until i stop an take off.
Once it got warm an all it wouldnt die but still bogged down some on take off.
Any advice for a newbie?
Most likely you need to install a new glow plug. This is a common issue for new Nitro owners unfamiliar with the engines. Brand new out of the box its common to foul them just during the initial break in. The stock Traxxas plugs are okay at best. OS are the way to go. Better quality and usually less money. But depending on the tune, even OS will foul out.
IF a new plug doesn't fix it, then probably set to rich. They do come rich from the factory for break in purposes. So you will want to spend some reading time. The manual covers tuning. Read carefully and keep in mind that there is a factory default position in case you go to far with the settings. Only adjust in small increments as the manual will tell you. Having a decent infared temp reader will come in handy. Sort of a must have item to own for nitro engine tuning.
Oh and the other thought. Is that you cant just 'fire up and run WFO'. Nitro engines are cold blooded beasts. Even well tuned nitro engines need to be warmed up for a few minutes before they will burn the fuel properly. Nitro engines are also very finicky when it comes to air temp extremes and high dew points(@64 or above) levels.
