Traxxas Monster Truck forum Discuss the Traxxas T-Maxx, E-Maxx, Super-Maxx and all other Traxxas monster trucks in this forum. You may also optionally discuss them in our MT general discussion forum.
I need tmaxx help
Old 10-15-2003, 05:09 PM
pamaxxposse
pamaxxposse's Avatar
Default I need tmaxx help
I just completely put my engine back together and am sure i tightened everything. After about 10 minutes, I noticed oil on my exhaust pipe again. How did it get there. Is there a small hole in my fuel line or is it coming from my carb?
Old 10-15-2003, 05:45 PM
jval144
Default RE: I need tmaxx help
check your fuel lines look for a pin hole
Old 10-15-2003, 11:21 PM
frambo
frambo's Avatar
is it on the pipe or on the header? if it is on the header, check your header gasket for a leak...
Old 10-16-2003, 04:18 PM
j-maxx
yea check u lines ur header gasket and did u put the copper or brass gasket in between the engine case and the cooling head
Old 10-17-2003, 05:39 PM
pamaxxposse
I just retightened the header before this. How would i check for a pin hole in my fuel line if i can't see it with my eyes?
Old 10-17-2003, 05:58 PM
Tigger N. Bennie
Tigger N. Bennie's Avatar
Blow through it like you would a straw or just replace it. While you are at it you might as well check the fuel tank and fuel cap for air leaks. The cap has an o-ring under it that can be tightened. Some of the older fuel tanks also have a primer which is known for air leaks--I guess that is probably one reason Traxxas replaced it on the latter T-Maxx 2.5s.
Old 10-17-2003, 06:25 PM
Mr. RCGuy
Just a suggestion clip off the zip ties on rubber coupler and install new zipties and cinch them down very tight
