T-Maxx servo glitches?
TX
I have a SportMaxx (with a 2.5) that has been converted into a T-Maxx through installation of the various necessary upgrades. Lately I've been having trouble with the throttle servo behaving very strangely. Sometimes the servo will seem to randomly change center so that the brakes are almost fully applied. When that happens, I can still play with the throttle on the transmitter and get the servo to move, but it won't move enough to disengage the brakes and open the carburetor above idle.
To try to fix it, I have taken the horn off the throttle servo and re-centered it. This cures the problem for a few minutes until the servo again re-centers at some random location in which case I have to do it all over again.
At first I thought maybe the throttle servo was dying, so I physically switched it with the shift servo. I still have the same problem. Whichever servo I plug into the throttle channel on the receiver has the same problem.
I also have a Venom failsafe plugged in line with the throttle servo. I disconnected it so the servo is plugged directly into the receiver, but the same thing still happens.
All the radio equipment is stock. The receiver batteries are 4 fully charged NiMH AAs.
Anybody got any ideas?
Mark
Mark
TX
RE: T-Maxx servo glitches?
ORIGINAL: jefx
Sounds like your servo horn is stripped, and when you apply the brakes, the horn repositions itself.
TX
ORIGINAL: homelessduck101
Its either ur not gettin enough power to it,too much power to it, or its stripped.
-Dallas
-Dallas
Thanks for the help guys,
Mark
