new cooling system by rbinnovations
the new cooling system by rbinnovations is pretty cool it has a fan hooked to the cooling head i just saw it check it out i wonder how good it works
RE: new cooling system by rbinnovations
it also uses a new cooling head design as well. they claim it helps with aftermarket part height clearance if anything they look cool im curious about the whole electric fan idea i might get one for the hell of it
i may well b wrong but wouldnt the added weight of the extra batt to run the fanbe a minus ..and woudnt the heat transfer from the head and acumilate in the fan. an perhaps burn it out it might not be so bad if the fan had a clearance between itself an the heads btw the head an tube style looks the nuts.
i forgot how would the air escape if the tubes were closing the screw holes
skliffy
skliffy
i think that the fan is in the wrong spot to help get rid of heat it would just recirculate again li you said. you would be better designing some sort of ram air type deal on the cooling head. i got a couple ideas im going to try once i get a new body and some extra lexan.
the website is www.rbinnovations.com they have great ideas i think but some stuff they make is a little too new right now. i recently bought their supercharger for my truck but i cant figure out how to make it run right so i took it off until someone comes up with a way to mkae it work but check out the website.
u guys r all wrong the rbinnovations fan is actually a turbo charger which uses the fan to suck more air into the engine giving a faster burn rate and much better performance
hey axle you swede look and read the whole post.
good glow igniter issue perhaps you would have to have a remote starter like some planes have them ont he fuselage?
http://www.rbinnovations.com/newsite..._exchanger.htm
scroll down to bottom of page.
by the way maxxer2.5 if i were u id sell that supercharger of yr's unless you plan on fitting a fourstroke mill
(not much of RB's stuff is thought out very well) is it???[&o]
cheerz
cheerz
yeah i know i took it off my truck and i am about to take it to the nearest hobby shop to sell it. that was a mistake i wont make again
they run about 190.00 but i would try to find someone that has got it to work correctly first. if you do then let me know. there is a guy on the website with an onroad car that claims he has gotten his car to go 101 mph but i doubt it.
MO
How much would you be willing to sell it for? I may be interested. Your truck looks so awesome. Where did you get the extra shock mount?
yeah maxxer just browsed yr gallery sweet truck geeza
uv gone 4 the show chrome shine look i like it
i noticed u got the carbon chassis>> doesnt that give a little flex?
and r u impressed with yr sway bar shok im interested in it but not sure peeps say its got to much hype?
cheerz
cheerz
what do you mean extra shock mount? um right now im not sure i want to sell it. i know everybody sais sell it but i think they will eventually figure out that everybody is rippin on it and they will fix the problem i dont know maybe im in denial! that shock is steering stability to help with roll, nose dives, bottoming out, and cornering. it seems to work pretty good but i need to change the oil so it isnt so stiff. i got it at www.rctrix.com you can get it for front and rear but it doesnt work on the back if you have rear exhaust like me so im probably going to go back to side exhaust so i can put my other one on balance the truck better.
who of us r u on about i dont whant to bye ne thing off ya
no offence like
what bout yr carbon chassis flex. i kno its feather lite or r they mega thick to make it regid
no offence like
oh crash kid was wondering if i would sell my supercharger but i got the carbon fiber chassis because i didnt want the alloy one at the tim but i think now the time has come and i want the UE EXT chassis but its like 300 bigones so im holding off. thanks for the compliments!
