Revo 120mm or 90mm
Revo 120mm or 90mm
I just got my Revo today and I thought about swapping the 90mm stock rockers that are installed for the 120mm rockers that came with it. I read in RC Nitro that the 120mm ones are a bit better. What have you guys done with yours?
NC
RE: Revo 120mm or 90mm
There's nothing wrong with swapping the rockers to see the difference. However, keep in mind that the Long Travel rockers were designed for climbing and extremely rough terrain applications. They will bottom out easily on jumps and they offer no progressive rate characteristics at all, which will give you a lot of body roll when cornering.
So whether they are "better" or not hinges upon what you'll be using the Revo for. 95% of the Revo owners out there will be better off using the P1, P2, or P3 rockers.
NC
The stock rockers are P1, and is what I'm currently using. I have a set of P2, but haven't used them enough to offer a good opinion yet.
ORIGINAL: Misbehavin
So, other than what is already supplied in the truck, you just need a bottle of 50 weight shock oil and one pair of black springs.
I hope this helps.
NC
You are correct in being able to go that route davechappelle. However stiffening up the suspension, so that it will not bottom out, decreases the handling ability in general over the smaller stuff. So you're robbing from Peter to pay Paul.
Plus, most people prefer more travel for something such as climbing or rock crawling. In those cases you don't want to increase the firmness of the suspension, but rather the opposite if anything.
The best route for jumping is a progressive setup. That way you still can be sure-footed on the small stuff, but yet have the suspension stiffen up when landing bigger air. It's the best of both worlds.
NC
I don't have it in front of me, but I generally keep the adjuster set down about 3mm from the top of the shock, and the tie bar in the middle hole on the lower suspsnsion arm. On rougher terrain, when I think ride height may be an issue, I may raise it up some usually moving the the tie-bar to the inner hole. However for the most part I like the truck to sit low which helps with the center of gravity, and provides plenty of downtravel. You do not want to remove a lot of the "sag" (ride height) because you'll kill the truck's handling ability. Remember to keep the tires in contact with the ground, you need the ability for the shock to travel up and down.
