Revo Will Not Shift Into 2nd.......
NY
I can not get my revo to shift into second gear . I have tried leaning and richening , from 219 degrees to 280 degrees. It will not shift??? Any suggestions, out trying now to get it right so i'll be checking in . Help, thanks
RE: Revo Will Not Shift Into 2nd.......
How many tanks have you run through the truck?????
How many feet have you given it to change into second????????
Has it ever shifted gears before?????????
What glow plug are you using???????????
NY
I am on the 12th tank
I have given it around 45 yards to shift at least
It was shifting yesterday
I am using the OS Lc 3 or C3 hot plug
I bought 2 A3's but have not used them yet.
NY
I have it figured it out, well not really it fixed itself. The truck is running flawless, shifts perfectly. I don't know it just happened? I must say the revo is pretty damn durable, i had some pretty hard wacks into stuff and smashing flips end over end and haven't even bent one thing as of yet. I'm impressed with it.
AL
In the manual it tell how to change the shift point.
Open the dustcap on the tranny case and then spin the spur gear till you see a hole, hold the gear there, then roll the truck till you see another hole, stick the smaller allen wrench into it and turn the way you want it.
