MAXX Snow Plow
MN
SD
RE: MAXX Snow Plow
ORIGINAL: oatmealman
make one,but y it won't have the torque o plow snow,oh sigh
MD
RE: MAXX Snow Plow
that link there^^ it says "this item is no longer available" towards the bottom right next to the pic of the plow.
RE: MAXX Snow Plow
ORIGINAL: smaxx3.3
RE: MAXX Snow Plow
I am thing of going to home depot and getting some vinyl and maybe some half pipe brakets. Its just I dunno how I would mount it. Maybe I could connect it with an extra servo so when I go in reverse the plow raises I just have no cloe about how I could hook it up to the car. Boy would a plow be awesome on my savage! It weighs at least 3-4 lbs more and the engine has a lot of torque, too bad it dont have reverse, then i would really like it[] I dunno tell me what you think.... And for those of you who already have built your own plows. Please post pics of it and give us a list of the parts that you used to make it[8D] TY Tom.
MD
RE: MAXX Snow Plow
quote:
ORIGINAL: smaxx3.3
quote:
http://www.hobbyetc.com/cgi-bin/item.cgi?part_id=24831
thats cause this is a 2 year old thread.
ORIGINAL: smaxx3.3
RE: MAXX Snow Plow
Maybe ill pay a visit to Home Depot on friday. I am interested in going through with this project. But I have to buy a new pinion gear for my diff first[:'(]
PA
RE: MAXX Snow Plow
hi rc nitrohead dont for get the skids on the bottom of plow i would use air plane tail wheels for skid know what i mean?[sm=spinnyeyes.gif][sm=spinnyeyes.gif][sm=spinnyeyes.gif][sm=spinnyeyes.gif] also use a 8inch aluminum pipe cut in half as plow any thing smaller will look odd imo
1 Post
RE: MAXX Snow Plow
sounds like an interesteing project, i think someone did it with a kyosho blizzard...
and i think if youve got a FOC then the 3rd channel could be used with an aircraft retract servo to raise/lower the plough... you may need some paddle or aggressive tread tyres to get the grip though...
RE: MAXX Snow Plow
It is an interesting project. I was supposed to hit home depit after skool today but I went to my LHS instead. After that I didnt want to walk the 8 blocks to the store cus I was very cold like 20 farenheit here. I just want the people who have done it:
mksuperbike
rcfreak11
Guys please post pictures! I want to see you plow to bumper linkage!!!!!!!!!!!!!!!!!!![]
mksuperbike
rcfreak11
RE: MAXX Snow Plow
Wow I dont know why you guys posted that you had made plows. I mean I want to know how you hooked it up to your truck and ive asked for pics, please post them.[]
MA
RE: MAXX Snow Plow
Here is my plow project for my stampede.
I used a 4" piece of pvc pipe cut that in half and then shaved the bottom to a blade. As of right now the plow is to wide i need to cut about an inch off each end.
I drilled 2 holes in the front bumper of my stampede and then 2 holes in a broken bulkhead off of my old stampede and bolted the bulkhead to the bumper using 2 stainless bolts.
Then i used a lower stampede a-arm mounted one end to the bulkhead using a mini screwdriver as a pin because its all i have for now. and then the other end to the plow and i made a little piece of wood to angle the plow for now ( will be replaing the piece of wood with something better). That piece goes directly in between the a arm and the plow. I then used a wood screw to go through the plow and then into the wood and then the a arm.
For scale details i found model chain at tower hobbies to mount to the servo to raise and lower the plow. the i got a little piece on rod to fit into an antenna tube and then bent the rod into an L and then cut the antenna tube to fit over it. Im gunna paint the plow yellow and get some fisher stickers to put on it.
here are a few pics. The flash on the camera wasnt working right so they are really dark ill try to take some better ones soon.
Hope this helps,
Matt
Hope this helps,
Matt
RE: MAXX Snow Plow
Hey thanks for posting, looks innovative[sm=thumbup.gif] Im gonna go for something more realistic[>:] I was supposed to hit Home Deopt today but had a change of plans since a friend came over But anyways, ill be going there to browse for materials and see what the price on everything will be (low on cash)[&o]. I am planning to use a flexible cut of vynil. My dad has that and itwould be very good for pushing snow as it is solid, but is very flexible at pressure so it can absorb impacts and retake its form unlike the PVC pipe, im saying if you were plowing at 5-10mph and you hit a rough part of concrete[:'(] I will try too look for some half pipe brackets that are at least around 5-6" so it can give the vynil the curved shape and then use some straight metal rod to join the brackets horizontally. Im going to want it at an angle just like you have it but not that far away from my truck so I will probably had 2 metal plates connecting to the plow brackets screwing into the shock towers for extra durability. I think this project shouldnt cost me more than $10 in material and a few hours at the bench. I cant wait until the powder flies in! We had our first flakes here in NYC on Friday but it was barely noticable Just a few, barely enough to see
This is a makeshift diagram of what im planning:
The plow: /////// Angled upwards to the left because the snow should always be pushed onto the right.
MA
RE: MAXX Snow Plow
The pvc pipe is pretty stong. Plus the stampede is very light there for not much momentum to really force pressure on the plow upon impact.
But i was also trying to figure a way to mount a spring just like a real plow so if it hit something it would fold forward.
This whole project has cost me about $4. The t-maxx parts were broken parts i had lying around. My dads a plumber so i have all the pipe i need, but luckly found the right size scrap piece. The bolts i found in my garage.
So far all i paid for was the chain and the antenna tubes.
-Matt
-Matt
RE: MAXX Snow Plow
Well I guess ill be hitting Home Depot monday I think my dad has some of that vinyl left over but im imagining that the PVC pipe would be kind of heavy to push. Is you stampede electric or nitro? But a Pede is kind of small so I wouldnt imagine it could have the weight or the torque to move more than 1" of snow at a time[] Ill see what I can do[8D]
WI
RE: MAXX Snow Plow
I made a fairly realistic snow-plow for a monster truck some time ago.
A few words of caution. Use something to protect your servos. I used a steering servo-saver for the servo that controls angle, and springs to protect the one that raises and lowers the plow. I went through a few servos before I added the protection.
I used aluminum for most of the plow, but I still had to beef up the front springs. At the time, the only truck I had was 2 wheel drive, so I added chains to the rear tires, and locked the differential. I also lowered the gearing, and strapped two 6-cell packs on it.
I eventually ruined the gearbox, and they no longer make the truck I used, so it will become a shelf piece. []
I don't have any pictures handy right now of the design, but I did take some video of it while it was still working. I may upload the video to You Tube.
