Replacing 2.5 Carb Body
SC
Can the 2.5 carburetor body be replaced without removing the engine? Also are their any things I need to look for when replacing the carb body?
RE: Replacing 2.5 Carb Body
udont have to remover engine u just losen up that nut and pull the carb out make sure u dont scre the stuff into the carb to tight the threads in the carb bodyt i found are very weak just get it tight dont overdo it i wasted money on one carb body that way..
The carb. body Il set you back about 15. bux might want to pick u some new seals for it to comes with the rebuild kit, OS makes a 10d carb. that fits the 2.5 for about 67. bux if interested, RED
