Waterproofing The REVO
RE: Waterproofing The REVO
no but commonly used items are silicon o-rings(like in the bottom of your shocks) to go between the servo and the horn, then pack some marine grease at the same area. take the 4 screws out of the top of the servo(just a little) and put some silicone sealant in there and close it back up. all other electronics get stuffed in ballons and zip-tied shut.
these steps will not water proof the truck, but will go a long way to resist water damage.good luck[8D]
TX
well im only wanting to wash it easily... with the water hose so i dont have to take everything apart im not going to drvie in water or mud or anything
CA
ORIGINAL: smitty4
I use an ecologically safe brake cleaner to clean off my truck when just brushing stuff off isn't enough. Doesn't leave a residue and dries almost instantaneously. BE careful as some brake cleaners may attack certain plastics.
Hope this helps
MS
www.plastidip.com
dip all ur electrons in this and ull be good to go, for servos just peel enough off so it can turn.... packing it with some grease as talked about above isn a bad idea either
