Tmaxx Temp Question
Tmaxx Temp Question
My tmaxx is leaned out just about to the max and no matter how long i run it hard the temp doesnt go over 120-140f this seems to be pretty low with what ive seen ppl posting about their temps, Is this bad for the engine to run this low ? other than that the truck is running sweet as, wheelies on demand and speed is amazing !!!
RE: Tmaxx Temp Question
i dont know how much more i can lean it out, and i got plenty of speed out of it. Is it bad to run it at those Low Temps ?
Well not totally stock ,,,,, different shocks, wheels, pipe and a cpl of body mods but the engine is stock and hasnt been touched,,,, im still scratching my head
At what point after starting it are you taking the temps?? Those temps are not right and you should be above 200f for normal operating temp. If you run it to rich it can ware out your engine alot faster.
PA
Are you sure it isn't 220-240 F? It shouldn't be possible to burn fuel in the engine without the temps climbing well over that, unless your taking the temps right after start-up.. You don't live in antarctica do you?
Nope im not in antartica,,, LOL ,,, ok here is what i do, start it up let it run for about min stationary to warm it up a little and then GO. and i dont take the temp right on start up or while its off,,, i go pretty hard b4 i check the temp, atleast 10mins of running it hard b4 i check.. ohh and im using 15% fuel aswell, Morgans Cool Power
ok where specificly on the engine are you taking the temp if you take it on the top of the cooling head it will be that cool you need to measure at the glowplug
i think im just gonna keep running it the way it is, doesnt seem to be causing any performance probs, the thing go's like a rocket
PA
It should run like **** that cold. I can't believe your getting proper ingition throughout the RPM range with those temps. But if its running well, I'd say don't sweat it. Although your engine will not break-in properly unless you are hitting the target temp range.
temp being taken at the glowplug,,,, im just wondering if it maybe the fuel that im using at the moment, the engine was broken in with 15% cant remember the brand but had about 4ltr thru it .... but the fuel that im using at the moment is cool power 15 % and ive only had these temps since ive been using this
PA, ANTIGUA AND BARBUDA
i think you better check yout temp gun again, cuz 120-140 C = 240-280 F, which would explain wheelies and speed.
there is no other logical explanation.....
