s maxx motor problems
alright since i got the truck it been a money whole first got it out to break it in hit a mailbox doin maybe 10 broke the top a-arm then the spur gear goes and i was do the stop and go thing nothing extreme now 6 tanks later the motor runs really really good then once it gets up to it temp i will gun it and it stalls just stalls so at first i thought it was to lean but there was a little smoke their so i richened it quite abit where you could see alot of fuel coming out of the stinger but everytime it get to temp it stalls please tell me what to do i don't have the money for a new motor [:@]
WA
RE: s maxx motor problems
Bro if you boggin out when your gunning the motor you might be to rich, lean it out 1/4 turn at a time until the motor will clean out
WA
Bro if you boggin out when your gunning the motor you might be to rich, lean it out 1/4 turn at a time until the motor will clean out .....also check your glow plug or change it
Tune it for performance at half tank, because the design of the fuel tank isnt a very good design so when the fuel gets to half tank tune it. When the tank is full your engine will be a bit rich but when it ets to half tank it will kick in.
Yep. There is almost always talk in the traxxas forum about the ofna tank. does require some mods but from what i can tell it is well worth it.
