quick evx ESC question
CA
hi, for the evx emaxx ESC there is 3 set profiles. profile 3 is 25% reverse. does this mean if i picked profile 3, 75% power would go into forward? does this make my forward faster then or does this JUST slow my reverse down?
NY
RE: quick evx ESC question
yes.... you will always have the same forward speed, it might effect it a little tiny bit, but nothing noticeable at all. IT is for the type of driving you do, and also it gets rid of the risk of chewing it up by hitting forward to quick from reverse.
CA
are you sure, becuase on my old esc, i was able to control the amount of % going into forward. i thought i would be able to do the same with the evx esc. i remember seeing something like 75% forward and 25% reverse or brake. i thought you said its always 100 %.
how bout the novak cyclone esc. can i make more power goin forward and 25% brake. if i wanted most of the current in the forward...do i choose the profile with more drive frequency and less brake frequency or the opposite? i dont get what this all means?
MN
everything should be answered in the EVX manual that traxxas provides for free on their website at http://www.traxxas.com/products/acce...df/evxaddm.pdf
IT IS A .PDF YOU HAVE BEEN FOREWARNED!!!!
