receiver battery pack
hi whatsthe best size rechargable battery pack to use i have baught one from a model shop it doesnt seem to last long, so if you could give me some ideas and how much they are please,and thanks for the info on tuning it goes like stink now,not sure wether it changes gearthough should you be able to hear the change, thanks guys
RE: receiver battery pack
you should be able to hear the shift by the differance in sound from the motor. The way that a car drops RPM's the motor will to. If you are not hearing that change in sound similar to any car changing gears, then your not.
PA
I use [link=http://www2.towerhobbies.com/cgi-bin/WTI0001P?&I=LXFJT1]this[/link]
and [link=http://www2.towerhobbies.com/cgi-bin/WTI0001P?&I=LXHCF1]this[/link]
Charge it up and it lasts all the way through a long bashing session. We were out for about 8 hours last weekend running most of the time, and it still had lots of charge left at the end of the day.
mine is a hump back but only 600 mah ,it only seems to last about 40 minutes maybe less and its new may be its faulty , thanks for the info
