One wheel not tracking straight, the other is..
LA
Ok, it started when i was jumping, I landed more nose first and when i turned the truck around and had it coming at me I could see that one wheel straight as normal and the othere was turned sideways. If i mess with the steering trim i can get one wheel straight , but the other is croooked and its almost impossible to drive. I took the wheels off and cant find anything thats broken. Anyone know what the problems is?
Thanks!
Thanks!
RE: One wheel not tracking straight, the other is..
Check the connecting rods. On mine one of the ends got pulled partially out and this messed up my front end alignment. I removed the rod, put it in a vice and was able to push it back into place with a small hammer.
Steve
Steve
AL
all u did was pop a couple threads on yur steeering linkage. take your wheel of and the one that looks realy long screw it in
LA
Just discovered the problem, it was a broken upper a arm and I noticed the rear turnbuckle was bent. Every single time I have been out jumping the maxx I broke something!
