all emaxx owners....
CA
hey wassup yall. hey can somebody help me out. im trying to progam my evx ESC to profile 3 (75%forward / 25%reverse) it says to hold set button till green. i did that. then it should blink red 1-3 times depending of the profile you wanna choose. profile 3 means 3 3 blinks...but it only blink once and without me pressing the set button. it just turns back red as in i chose profile 1. i went to traxxas website but my retarded comp cant open up that file. please help thanks
TX
RE: all emaxx owners....
keep pressing the button after you see the green one until you see three flashes of red. also the 75% throttle means that you will have more throttle control but not as much in reverse. thats how i run mine
CA
ohh..your suppose to keep pressing the button untill i see the blink 3 times.....i thought i was suppose to hold set button till it turns green, then let go of button..then it should blink3 times. THEN that s when i press the set button and it should set as that.
CA
excuse me...profile 3 is 100%full throttle and 25% reverse. does anybody know if my emaxx will go the same speed going forward if i chose the one touch set up(none of thr profiles...but the one where you have to manually press full throttle , then reverse, then neutral) is there any difference between these two besides the reverse will be slower on profile 3.
will the profile 3 make my forward faster since its 100%forward compared to the one i do manaully?
MN
forward is ALWAYS 100% you cant exceed that, nor decrease it. It is set like that, and there is no way you can change that. profile 1 is 100% forward/brakes/ 100% reverse. Profile 2 is 100% forward/brakes, NO REVERSE, and profile 3 is 100% forward/brakes/ 25% reverse.
Having a slower reverse has nothing to do with forward speed. THink about it. Why would that even matter? You have to ask yourself these questions.
ORIGINAL: blueb8llz
http://www.adobe.com/products/acrobat/readstep2.html
CA
ok got it its just that on the old esc..i think...the more power u put on reverse or brake.the less power you have going into full throttle so i thought the evx was like this too.
so your saying no matter what setting i choose...even the one i do manually, the forward speed will be the same right? so does that go with my cyclone ESC as well with those settings?
