T Maxx Problem ( Stripping Forward Gear )
My T maxx keeps stripping the forward gear well shredds it more like ??? Any ideas how to solve this problem
I get about 5 mins play with a new forward gear ???
i know rpm do a steel forward gear is it worth getting this ??
RE: T Maxx Problem ( Stripping Forward Gear )
Is your motor binding up against the gears? Are they pushed together too tight. There should be a minuscule amount of play in there.
AL
there is somthin seriously wrong if u are talkin about the tranny gears that are in side. .but it is somthin not that seriuos if its the spur gear
IN
I used to strip the forward gear in the tranny too. I had run the truck for over two years and then it just went. I replaced the gear with stock. Now I have a sirio 23 and I stripped it after about 5 min. Now I have installed the robinson racing forward gears. Be sure that if you get them, you get both forward gears, just the one will not work.
Now that I think about it, you should take the tranny a part and check the condition of the bearings that the shafts seat into. May be the the bearings are worn or the plastic tranny housing were the bearings seat in is worn. This could cause the gears to not mesh correctly.
It's the one in the tranny
I ve replaced the forward and reverse for the RR Metal ones but the edge of the froward one is wearing and it's started to srip the drive gear part No. 4998 ????
It's costing me a fortune it lasts about 3 full tanks of fuel and it DIES
Any Help ???????
Also Should i put any grease in the tranny ??
Any Help ???????
Alittle grease goea a long way on metel gears.Also check your bearings that the shaft rides on.Also have you change out the shaft?I't could be warpped.Slow
