Revo bogs down
RE: Revo bogs down
Perhaps the engine is running a bit lean at higher revs, try richening the hsn and see if it helps, if not then i'd strip down the tranny and see what you can find.
RE: Revo bogs down
There is no binding and I took apart my tranny and there is no wear at all. Iichened my high speed needle also but it didnt help! Are there any more ideas?
I have only had 2 gallons of 20% taxxas fuel throught it if that helps. Also nothing is tight and I made sure I put it back together correctly.
RE: Revo bogs down
WAIT! LMAO, I had to RICHEN IT. Sorry, I had the exact same problem and posted in a thread a while back. Here ya go.
http://www.rcuniverse.com/forum/m_27...tm.htm#2784991
RE: Revo bogs down
I replaced the glow plug and it still does it. As fo buying a new moter I was gonna do that but then I bought a PSP instead. If none of those things work then I will check the HSN for debris.
RE: Revo bogs down
Did you view the post that I had given you the link to? I had the EXACT same problem and did what the guy in that thread told me to do and was runnin right.
