revo big block conversion
KY
Anybody out there done this conversion ? Were trying to put a picco .26 in a revo but can't get it to clear the rear suspension. The starter is too thick.
KY
RE: revo big block conversion
we are useing the revo conversion kit from traxxas and have both pull start and e-z start. neither will clear the upper control arm. if we move the engine foward the bell clutch hits the servo box.
KY
Thanks Guys, found the info we was needing at extremercmotorsports.com , you have to have a non-pull start engine and use a starter box.
NY
ORIGINAL: thewoodshop
OH
you can't use the EZ start or a pull start on the revo when you go to a big block??? If not I don't think Traxxas thought this one through enough for the one's that like more power.
i have a revo with a sh28 i got the new era mount it works great and you can use pull start or roto start.http://www.neweramodels.com/item.cgi?part_id=2553
