revo wont stay on the ground.
put a big block on my revo and know the front end comes up to easy what can i do to prevent this its cool but to much i still want to drive it, maybe suspension or different gearing?
PA
RE: revo wont stay on the ground.
yeah just take off slow and when somebody is looking and says its weak then just punch it so it flips over backwards......... that would always work.
Loosen the slipper off a bit and either
a: buy some weights and fit them somewhere on the front end
b: use something around the house to weigh the front end down
hmmmmmmmm should it stay on the ground ? no way never not a Revo lol j/k my #2 truck has a Picco .21 and I have to have a easy trigger finger with it . and really when it changes in to 2nd gear . sideways it goes in the dirt . but it is all good . http://groups.msn.com/BaddsTraxxasREVOGroup
AZ
ORIGINAL: BaSh_2_tHa_mAxX
HUH ^^^ [&:]
Also i forgot you could also go up a few teeth on your clutch bell so then you will loose some low end and gain top end. Just mess around and find a gearing ratio that will suit your needs.
You can put some weight on it in the front or buy a long wheel base chassis for the revo. BallisticBatteries makes a longer chassis and 3Racing will have a long wheel base chassis soon for the revo!
AZ
You know it's funny, I'm looking for a solution to getting MY Revo to wheelie, wiercc is looking for a solution for too many... let's just trade.
ill tell you one thing the traxxas header pipe is weak one flip and smashed it but im looking to gain top speed more than low end thats why i dont want to do insane wheelies.
Sorry im not really hijacking your thread but if i were to convert to big block would it work if i geared for extreme speed and lost all the torque by gearing for top end would it still require hundreds of dollars to make my maxx tranny stand up to a bb.
