3 shoe clutch
AZ
3 shoe clutch
I am going to be ordering my TM323 soon. This question is for those who have changed to a mid or big block... With the TM323, am I going to need to change to a 3-shoe clutch or will my stock one do? I've always been wanting to, but... not sure if I do now. Any suggestions? I mean, I know it will be better... but will my stock clutch last? Also, what about the airfilter? I know it will work, but will I have better luck with a Motor Saver, or should I just stick with what I have... and upgrade as necessary?
CA
RE: 3 shoe clutch
I'm running the MIP 2 shoe clutch with my revo with TM323. Also, I am using a MotorSaver, but I think the stock would work okay..
One bit of advice: this motor takes alot of tuning, so if you like the "Set it and forget it" mode that the TRX 2.5 runs in, you might want to stick with the stock motor...
When you do get it dialed in tho, it's awesome!
