need help
RE: need help
try a 16 bell with a 72 spur.................takes ratio from 3.5/1 to 4.5/1..................if it dosn't flip its lid then, i don't know what to tell you. oh yeah, this will slow your top speed big time. i'm going to 18/70 to get a 3.8/1 ratio........a little quicker......not much slower
RE: need help
If it is the 2.5 maxx it should be. Once tuned right it will flid it on its lid. Traxxas has video visual proof. And i have seen many videos that can back my statement up.
RE: need help
i've done it a few times.............but my 2.5 is very finiky...........one min tuned great.............next.............not so great..........yet another reason i see the os.18cv-r in my future
RE: need help
Well if you do the ofna take mod then the 2.5 wont be as bad as you think. For 15 dollars it cant be beat. By changing the tank out to the ofna primerless one and moving somethings around in your truck to make it work all your 2.5 troubles will slip away. Due to the heigh of the t-maxx tank and un evenness it sets the mixtures off and runs rich at full tank and dangerously lean towards the end explaining everyones tuning problems and high temps. If you want more info i can hook you up with a detailed thread on how to do this mod.
AL
RE: need help
u got to tune high speed first. get it so it it goes realy fast in 1/8 increments. then back it off1/8 . that should have it runin ok then run a couple high speed runs then bring it in and let it idle a 10 secound period . what does it do?if stays on idel for a while but has realy good top and smokes abit at wot the richen lsn alittle. then tell us what it does
