t-maxx throttle, need help now, PLZ!
FL
i installed a fantom FR.18 in my t-maxx and sometimes when i go full throttle the carb will stick and stay at WOT. what should i do to solve this??? should i get a throttle return spring? help, what should i do?
RE: t-maxx throttle, need help now, PLZ!
first, make sure its the cabr thats sticking, not the bellcrank. if its the bellcrank, loosen the screw a bit and clean it off. if its the carb, soak it in after run oil and nitro blast to unstick it.
GA
I've had the bellcrank stick before too. I fixed that by adjusting the linkages. I prefer adjusting the linkages as opposed to using a radio adjustment as it's a more permant fix and less likly to repeat the problem.
