Traxxas Monster Truck forum Discuss the Traxxas T-Maxx, E-Maxx, Super-Maxx and all other Traxxas monster trucks in this forum. You may also optionally discuss them in our MT general discussion forum.
a quick table to solve some common problems
Old 12-29-2005 | 10:50 PM
Default a quick table to solve some common problems
i hope this helps some ppl
Description of Problem
Cause of Problem -- Solution of Problem
Engine will not start
Out of fuel -- Fill tank with fuel
Wrong type or poor quality fuel -- Replace fuel
Carburetor not primed --Prime carburetor
Glow heater not charged -- Charge glow heater
Bad glow plug -- Replace glow plug
Engine flooded -- See Flooding
Engine too hot --Allow engine to cool
Carburetor set incorrectly -- Readjust carburetor
Blocked exhaust -- Clean or remove debris from exhaust system
Air filter clogged -- Remove and clean air filter
Starter will not retract
Broken spring -- Replace recoil assembly
Starter hard to pull
Engine is flooded -- See flooding
Engine is seized or locked up -- Take engine apart
Engine starts then stalls
Idle set to low -- Increase idle speed
Bad glow plug -- Replace with new
Low-speed mixture too "rich" -- "Lean" low-speed mixture
Low fuel tank pressure -- Check for blockage in fuel pressure line.
Engine overheated -- Allow engine to cool down
Engine sluggish or poor performance
High-speed mixture set to "rich" -- Lean out high-speed mixture
Leaking glow plug -- Tighten or replace glow plug
Old or dirty fuel -- Replace with new fuel
Carburetor dirty or blocked -- Clean carburetor, check for blockage
Engine overheating -- Stop running and richen fuel mixture
Slipper clutch set too loose -- Tighten slipper clutch
Tires not glued/wheel pins fell out -- Glue tires/replace wheel pins
Engine over geared -- Use lower gearing
Bound up drive train -- Check drive train, and make it free
Engine worn out -- Replace piston/sleeve and check connecting rod
Engine overheating
High-speed mixture to lean -- Richen high-speed mixture (counter-clockwise)
Cooling air flow is blocked -- Cut holes in body to allow air flow
Nitro content too high -- Run nitro content between 10-20%
Fuel not containing correct lubricants -- Purchase a higher quality fuel
Excessive load on the engine -- Check for bound up drive train
Low-speed mixture too lean -- Richen low-speed mixture
Engine stutters or hesitates
High or low-speed mixture too lean -- Richen high first then low
Engine overheated -- Stop engine and let it cool down
Engine stall as soon as you give it gas
High-speed too rich -- Lean high-speed mixture
Engine stalls when I let go of throttle
Idle set too low -- Increase idle
Engine stalls for no apparent reason
Engine overheated -- Shut off and let cool down, richen high-speed
Debris in fuel line -- Remove and retry
Poor fuel tank pressure -- Check hose foe clogging
Old 12-30-2005 | 03:33 AM
Default RE: a quick table to solve some common problems
Nice works SMaxx. Us newbies need all the help we can get sometimes. I suggest everyone who is new to nitro prints this list and keeps it in their kit box.
Keep up the good work
Old 12-30-2005 | 08:29 AM
zak33_33's Avatar
great work, very helpful!
My I am in the middle of the break in of my revo, and it goes fine for about 5mins, then the engine goes all sluggish and sounds very deep, usually i take it in shut it off and when i turn it back on it is fine. Is this normal?
id apprieciate any help,
zach
Old 12-30-2005 | 11:49 AM
no problem coupe
zak did you make any adjustments at all? if no, it could be yur glow plug is a lil bit fouled...if you can still run it, use it until you can get another to check it
Old 12-30-2005 | 12:10 PM
Sticky this
Old 01-03-2006 | 12:00 PM
zak33_33's Avatar
well i didnt want ot break anything so i have ordered a couple of spare glow plug, so we shall see how we go!
Old 01-04-2006 | 03:09 PM
nice
Old 01-22-2006 | 12:12 AM
snoking16's Avatar
some one really needs to sticky this
