just broke in my revo, i dont think i did it right
please look, help me out!!!!
ok this is gonna be a lil long, so i can explain what i did
well first off i when i was on my first tank when i pulled it to 1/4 throttle it would just idle and a higher rpm, and wouldnt move, so i had to go 1/2 throttle, i did that for the first 2 tanks
i figured id check out the temp of the motor just in case, when i did it was only 170????, i was like ***....btw it was 68-70 degrees out, this is when i had the body on, so i was like, well ill lean it out when i i get done breaking it in, so i do all the break in, and start tuning it
i leaned it out till it was idiling good, good accelaration, the temp was 230, is that ok?
last thing is when i was comming home i wanted to show my mom the revo, well the optidrive was blinking red, but since i was gonna barely run it and i THOUGHT the throttle return spring would stop it from running away i ran it anyways....well...it ran away from me, why did this happen, why didnt the throttle return spring stop it, was it because the battery was low?
anyways im getting a failsafe asap
sorry for the length but i really need to know asap, thanks
CA
RE: just broke in my revo, i dont think i did it right
Did you watch the DVD and read the directions on how to break it in? The red light was flashing because the battery was low on the Revo.
ya i read and watched the dvd about 5 times, and ive been reading about it for about a month and a half now, these things just caught me off guard
also, i reglued the tire with super glue, is that ok to use
GA
No, the trs will only return the throttle to neutral if the power to the reciever dies completely. When the batterys get low they let the reciever start to glitch. When it glitches it still has the power to work the servos. The trs will do absolutely nothing to stop that.
A failsafe will stop those kinds of runaways.
230 degrees is fine. It could even be a bit warmer and still be fine.
ok so if i get a fail safe then i dont have to worry about my revo running away on me ever again, thats the most important thing, i just spent almost 6 bills on it and i dont want it running away from me, it scared the **** outta me
ya i did but the thing that caught me off guard was that the whole time i was breaking it it, the temp was only about 180, and it was 70 degrees outside, thats where im confused
