just reguled my tire with super glue, is that ok
the only problem im seeing is that i didnt get the bead of the tire perfectly in there, its not in all the way, you can see where the line raises up a bit, will that be ok, or does the tire have to be perfectly in line with the rim
TN
RE: just reguled my tire with super glue, is that ok
OMG!! It's going to tear your wheel and tire apart. SUPER GLUE IS BAAAAAAAAD.
No. Tires WILL become unglued.. regardless of what you want. I use super glue, becuase I can get it almost anywhere, and it works just as good as CA glue
ha damn you scared the crap outta me, i know it will eventually come apart i just dont want it to come apart the next day i take my revo out
TN
It shouldn't.. maybe after about mm.. I dunno. Every 5 or so tanks, check 'em to see if they're coming loose.
