a dog ate my revo antenna / unglued tires
MD
question #1: so sunday i finished breaking in my engine. a pit bull that belongs to my neighbor bit off the antenna. i know i need a new one but how bad is it to drive around w/ my antenna only 4 inches long? i do have a viper green thingy rev, temp, and volt regulator. it is not instailed yet i am putting it on tomorrow. i will not beable to get a new antenna till next week.
question #2: also my tires came unglued. do i need to use rc type glue or is there a general type of glue that will also work?
thanks for the help,
ON, CANADA
RE: a dog ate my revo antenna / unglued tires
my antenna got cut about an inch long on my jato once, the thing is i didnt notice it, and i kept losing range every time i got 10 feet away, luckily i have a failsafe
MD
ok i am putting my fail safe on tomorrow. it is a gree box called viper w/ a snake on the front. my rc place is closed on mondays. i'll see if i can find another source for the glue.
later
super glue glue is a bit cheaper and i have plenty at work. sweet thanks!
later
ND
let me know if i am wrong, but i was told the the reciever and antenna were made together. so i am in the understanding that you will need a whole new reciever
if you still have the rest of the wire you can solder it back on but remeber to use some heat shrink over the soldered area so it can't make contact with anything to prevent glitching, also if you don't have the old peice use wire that is the same thickness and if you can make the length about 1.5 to 2 foot total length ask here if you need to know the length for your reciver antenna
MD
ok fixed it i had a nother wire same gauge. i spliced and soddered them together w/ shrikn. everything works fine. the green gadget is a venom. i got it hooked up and works well. i'm posting pics of it on my photo album w/ the new body sometime tonight. www.mikegardner.myphotoalbum.com
thanks everybody
thanks everybody
