TMAXX -MAGICWHEEL
TMAXX -MAGICWHEEL
Hey I really need help I have a clone of the T-MAXX the smartech magic wheel And I am Looking for as much aluminum hop up's as much also I am looking for the most an aluminum receiver box for this truck does anybody have aone of these trucks hooked up or does any one have an aluminum receiver case for it any one know where I can get one custom made thanks I need as much help as possible thank you
KY
RE: TMAXX -MAGICWHEEL
My bad I was thinking of skidplates. The brand was not even RPM!!!
I'm realy realy scater brained I guess. Were can I find these Rpm Boxes?? Also my friend has a sportmaxx{a 2wd tmaxx}And it's receiver case will work, with some drilling or couse[>:] He he he!!! but the battery box won't work, it's too long.Any Ideas????
PS does your MAGIC WHEEL'S receiver and battery boxes break a lot????
CA
Integy makes an aluminum reciever case along with a lot of other stuff, here is a link that has tons of different companies that make aluminum maxx parts.
http://www.beatyourtruck.com/links.html
NL, CANADA
Hey, I have a Magic Wheel too and I just got a Integy Aluminum front skid on it with no problems or modifications - looks sweeeet!
Hi all, new here. I made the mistake of buying one of the smartech magicwheels. But untill it breaks it is what it is. I've put the o.s. 18 cv in it and it moves along preety darn good. Must say that is one easy motor to tune compared to the pos that comes in the truck stock. Other things I've done are custom bumpers, rollcage aluminum shock towers,Ths 1040 header with a 1045 pipe, and piggy back shocks. My plans are to thrash it and replace the junk that breaks with aftermarket stuff. By the time I'm done with it, it will be a nice unit and nothing on it will be smartech.
[link=http://cgi.ebay.ca/ws/eBayISAPI.dll?ViewItem&item=6032848348&ssPageName=MERC_VIC_ReBay_Pr4_PcY_BIN_IT]this is the cage I've got coming.[/link] With the O.S. I had to get the t-maxx clutch and simply reverse the engine mount. If you want a pic I'll try and post it for ya. Put them up anyway
I forgot to mention that I did try to use the stock tmaxx engine mount, but it put the engine too far back to get a decent mesh with the cb and spur gear. Plan on useing it when I upgrade the chassis.
KY
So you just reverse the stock engine mount??? and get a t maxx clutch???
could you post me A Pic please????? what Model of OS did you get???
And were did you get from??? and would the stock exhaust work or did you have to replace it??
And if you don't mind could you tell me how much it cost to get the header and pipe???
Thank you so much for your help!!!!
KY
Oh,
I forgot to ask if you don't mind could you tell m how much the motor cost too????
PS do you know how to tune a pipe??? I sure don't!!!!!
Thanks again
Thanks again
[link=http://www.greathobbies.com/products/productinfo.php?prod_id=OSM18CVRSX]This is the motor and the price I paid.[/link] Got the clutch of of ebay for 15$ us. the stock pipe would work but it won't be the best. The 18 is a semi big block and needs a better set up than the stocker to run to it's full potential. To fit it it's just a matter of fliping the mount. The pipe header combo i got off ebay to. paid 26$ us for them. The only other thing you need is [link=http://cgi.ebay.com/Traxxas-Clutch-Adapter-Nut_W0QQitemZ6034090232QQcategoryZ44028QQcmdZViewI tem]one of these.[/link] It makes the clutch for the 2.5 tmaxx work with the short shaft os engine. [link=http://cgi.ebay.com/Traxxas-Revo-TRX-2-5R-CLUTCH-FLYWHEEL-KIT-T-Maxx-2-5_W0QQitemZ6034447630QQcategoryZ44028QQrdZ1QQcmdZV iewItem]This is the same clutch I got.[/link]
did the pics I put up not work?
ORIGINAL: ZoomZoom1
Oh,
Thanks again
Oh,
Thanks again
You don't tune pipes. If it says it is a tuned pipe it means it is designed for a certain engine
KY
The pics worked.
I just was not clear on witch mount to reverse.You got A revo clutch AND flywheel off of ebay???
Did you "TUNE" your pipe???If you did, can you tell me how??? By the way awsome Truck!!!
were did you get the shocks from???
Thanks again
Thanks again
[link=http://cgi.ebay.com/T-MAXX-2-5-CLUTCH-BELL-SHOES-PINION-GEAR-TMAXX-NEW_W0QQitemZ6034514960QQcategoryZ44028QQrdZ1QQcmd ZViewItem]This is the clutch I used.[/link] I put the wrong link in there. The tooth count is 20. That other clutch would work but 16 teeth would take alot of topend away. And yes it is the engine mount that you would turn around. That or just get an adjustable mount and be done with it.
KY
I can't find a pipe or header.Was you pipe for an OS??
The closest I could come is an OS pipe header for $150.00!!!!!!
TOOOOOO MUCH!!!!!!
TOOOOOO MUCH!!!!!!
KY
I found the pipe.It was $36 insted of $26.
Here is a link>>>>> http://cgi.ebay.com/THS-Racing-Tuned...ayphotohosting
Is that the right one???
Also were did you get the screws to attatch the header to the engine block??
