removing the optidrive
how do you remove it, i never use reverse, and its messing up my failsafe, where do you put the plugs that go into the optidrive, I looked at it and it looks lilke the throttle and steering plug go into the reciver where the 2 and 3 channel plugs are at, is that right or do i have it wrong?
also i dont want to get the FOC i just wanna remove the optidrive
MI
RE: removing the optidrive
Channel 1 is steering you don't have to touch this one and it should not be run through the opti drive. Channel 2 is the throttle and brake, unplug this from the optidrive and plug the servo into the receiver. Do the same with channel 3 which is the shifting servo. Now don't shift while it is in motion or you are in for a lot of work.
