T-Maxx Troubleshooting Thread
#151
RE: T-Maxx Troubleshooting Thread
How do i convert my narrow maxx into a wide one ? got some 40 series wheels coming with some losi maxx tires coming....i want my max WIIIIIIIIIIIIIIIIIDE.....
#152
OH
ORIGINAL: Por2ugee17
#153
Nice, i love that. Its stock, so its pretty narrow, but i have some 40 series coming in the mail with some team lost monstermaxx tires....whats your set up for a arms etc....
#154
OH
On the front I have the RPM 2.5 arms, and on the rear I have the RPM True-Track conversion. Got SPI alu. racing wheels and Pro-line bowties (standard Maxx size). In the front of the first pic (I changed the rear for the pic, I was in a hurry) I got some Pro-line Badlands on RPM Widemaxx monster spiders. (what I bash with.)
#157
I just got a T-maxx 2.5 used and I am trying to get it to start. I just replaced the one way for my ez start. it looks like everything is working right but the fuel is not getting to the motor. it goes through the fuel line but gets stopped somewhere before the motor. i put a drop of fuel in the motor and it sounded like it wanted to start. how do i get this fixed?
#159
i recently got into Rc's and have been working on a t-maxx v.1 with many parts from other trucks...ran a 2.5 engine in this week all tuned and broken in...
due to inexperience and wet pavement i lost control and slammed into a boulder that i had not payed any attention to.
the electronics are completely shot. i turn on the power switch and all i hear is a click sound once. i am not sure where to start troubleshooting. I haven't found any threads relating to 'no power to the servos" yet so i thought i would jump on this one and put it out there for some advice...thanks.
#160
Question 1: I have a tmaxx 2.5. I recently pulled the motor to check for air leaks and to clean it up. I put the motor back in, the t-maxx starts right up, but all the servos are very weak. The Throttle servo isn't strong enough to open the throttle on the carb. The servos are also glitchy. when I switch from forward to reverse or vice versa, the servo turns a little, stops, then turns a little more, then stops and keeps doing that (all the servos do that). I'm using brand new batteries.
Question 2: I don't know if this is related to the servo problem, but I'm having a transmission problem of it not moving when I give it gas (I pull the throttle by hand). I read a post where someone swapped in a new drive hub and it fixed the problem so i'm going to try that.
TIA
TIA
