Picco 26 Max....the DARK SIDE....
#1152
RE: Picco 26 Max....the DARK SIDE....
kasarn i see your running the vantage chassis and a side pipe. first question does the vantage chassis hold up ok with all the horsepower and does it tend to flex. second question are there any clearance issues with the side pipe and the rear suspension arms. last question is for any body do you know which majestic body steve slayden is running
#1153
ORIGINAL: quadracer111
What did you all get to bulletproof your drivetrain?
#1155
http://www.*********.org/car_rrp_traxxas.htm - everything from clutchbell to diff gears
Or try searching on ebay for 16.8v emaxx diffs... those are beef.
#1157
FL
ORIGINAL: nitrorcjunkie
Wow. I can't believe this thread is still alive......much like my .26 MAX, blue head. 4 plus gallons thru it, over 2 years since I broke it in. Had to replace idle stop screw, and got a set of Boca bearings in it. I was a participant in this thread since the beginning- garnered a lot of good info on this particular motor. Still get out and tear around the park with my T-Maxx. Can't hardly call it a T-Maxx,tho-the only things still stock are the tranny case, diff cases and bulks.
#1158
MA
ORIGINAL: crawlernate
#1159
I never knew e-maxx diffs worked in the revo...
Not sure if they do... I thought you had a tmaxx...
heres a link to the revo parts. http://www.robinsonracing.com/catalog/revo25.html
#1161
hey guys i have a question i have a 26 max that i have had atleast 2 years or longer my question is i broke it in on 8th tank it wont start new glo plug it seems to be flooding i dont know why it is doing this and i did put trinty pipe on we did replace the outer bearing could carb just start leaking i know im jumping around but this is all of theproblems im having can some one help please.
#1162
OH
ok guys,i was told to come her for my .26 max problems.i just bought it and started to break it in.the first tank i idled up to midrange and the second tank was midrange throttle sweeps.but it started to make this strange noise like it was sputtering.to describe the sound it sounded like i was blipping the throttle extremely fast and the idle is very rough.then it will rev like crazy,hit 280' and i turn it off.it looks to be a rather early .26 max and heard it could be a front bearing,is this correct? i used loctite gasket eliminater on the carb and backplate but it didnt help.whats goin on here guys? im using the original revo pipe but can i use a JP-2 from my 1/8 buggy too?.thanks...josh
#1163
just to add another question what is the expected life of a picco .26 red dot and how long do the bearing last on the crank. i keep blowing the rear bearings in the 3.3 traxxas motors and am thinking of switching to the picco for my revos. and can you put a back plate on the picco and make it a bump start motor. this may have been discussed here already but this is a huge post so sorry if its a repeat question.
#1164
TX
I don't know about the red dot version, but I've had my 1st generation Picco 26 MAX for almost four years now. When I had a leak in it, I sent it to OFNA and they replaced the casing and front bearing for FREE. All the new Picco's come with the new bearing and case. Good engine. WHEELIE monster![X(]
#1166
I have just got a picco max 26, I can get it to run, but itwill not stay running and will not idle. Could I get some help on where to start on the HSN and the LSN ? The paper that came with the motor is different than what the website on picco says.
#1167
Hi all, just bought two Picco's, a P2 .21 for my T-Maxx and .26 Max for the Revo.
The seller of the .21 recommended i give the engine a complete seal before dropping her in, can anyone give me any tips? Perhaps a small guide and tools needed? I would really appreciate it.
Also, its the T-Maxx/Revo drop in version, so i assume everything from TRX 2.5 should in theory bolt straight on?
Thanks and apologies for the necro post but i heard this thread was the best
#1171
Resurrection time......I know this post has been quite a while, but I'm in a fix. I am re-purposing a 26 max and my only option requires a rotary carb. ANy of you gurus out there have a good suggestion or even one that would fit just lying around?
--THX
--THX
#1172
Please can anybody help me with a prob? I have now got picco 26 max in my long wheelbase t-maxx 3.3, and I've got somebody to make the bb header conversion ring for me but I just need to find a header that will fit between my engine and rear shock tower. Does anybody know if there is one that will fit or will I have to try and fabricate one? The JP4 header that I have with the pipe is to rounded and it fouls the rear suspension tower so I need one that is a similar shape to the trx 3.3 header. Any advice I will gratefully appreciate (phew for the spell check). thanks in advance (fingers crossed) Paul
#1173
The .26 mid block is now replaced by the .28 mid block. Same procedure as before so it doesn't change anything. Uses the same mount as .26 also. http://www.nitrohouse.com/Force-JL-2...o_p_16050.html
http://www3.towerhobbies.com/cgi-bin...?&I=LXDUNN&P=0
Saw it on ebay for $157 shipped.
#1174
http://www.amain.com/ofna-jl-.28-max...engine/p265388
#1175
Picco wp3 .26 help
Does anybody know about this engine? I'm having problems finding parts for it. But I like that fine is an exploded view of the parts and what can I get to make it to where it's a pull start or a electric start. I don't like the bump box idea. Any information you have would be greatly appreciated. Thanks for taking the time to respond.
