stearing?
Banned
WI
stearing?
i have a 2.5 and the stearing is really bad on it and its to slow. i took off the servo off my emaxx and it does the same thing. could it be that i need a better servo or is it the servo saver
MD
RE: stearing?
Check the steering bellcranks for binding, and check that your pillowball retainers make sure they are not too tight, also make sure that the screws that hold it in place are not too tight. If you are running stock stuff it is an area that I would reccomend upgrading. You can improve the stock bellcranks by replacing the stock bushings with ball bearings.
MD
RE: stearing?
ORIGINAL: SharkDiver
Look in your owners manual.It should have a diagram of everything on your truck.
Shark
Shark
Here ya go
http://www.traxxas.com/products/nitr...5r_chassis.pdf
http://www.traxxas.com/products/nitr...x25r_front.pdf
Banned
RE: stearing?
you can get 8mm bearings i think it is and replace the plastic bushings in your steering bells and your throatle bells. which will lessen the drag. therefore make steering easier and more robust. a GOOD servo will help ALOT too. i use a JRZ9000T @115.00. but a 50.00 hitec hg645m will work well.. personally i like overkill on my steering..
Timmahh
Timmahh
TX
RE: stearing?
Go here and there is a step by step with pics........ http://www.misbehavin-rc.com/pit-lan.../tm-bumper.asp Hope this helps.........GW
