flywheel
FL
flywheel
yoooo!
hey what type of performance does the 40mm flywheel help....never had to change a flywheel and i dont like the looks of my stock one...ne users?...thanks
BTW will it fit on my 3.3?
http://www2.towerhobbies.com/cgi-bin...I=TRAC4143&P=K
RE: flywheel
They only gain would be a larger area for a bump starter. You might actually lose a little with the added mass.
Yes, It should fit on the 3.3, but not sure. I think the 2.5/3.3 Maxx, Revo, Jato, .. use the same flywheel setup.
IL
RE: flywheel
Yea it will fit. The 2.5r and 3.3 are the same engines just one has blue parts so they can jip u on which to buy. And i dont know why u would even want to change it. Ur clutch will just cover it up.
