diff spool! do u suggest it?
AE
hey guys my track is very dry and has alot of loose dirt ontop so much that you have to ease out of the corner or else away goes the back end so anwys just want to know what u all think and where would i instal it in frt or back i ve heard that if i put in front it will help the front end pull and i could kinda learn to drag the back end around the tight corners well just need tips and advice
My Feedback: (-1)
Install the rear brake kit, and set the front brakes for strong, and almost no rear braking power. This will allow you to lock up the front, while the rear still spin. If you do it right, you can go full speed to the corner, hit the brakes, and pivot around the turn. This is a good trick to learn
AE
hey im putting it in my revo 2.5 but i just ordered a 3.3 chassis and im getting ready to do a whole parts transfer and ill post picks soon. my plan is to have like two extra sets of diff's for different track conditions since every track here in germany is so different. i want to have 1 diff w/ spool in it just in case so just wondering if i should and where to install it frt or rear
