Revo suspension?
Revo suspension?
Just recently I tried the long travel setup and really didn't like it. So I'm going to go back to the P2 setup, and lower the ride height. I want some stiffer springs, could I use the ones from the long travel set and use with the P2 rockers? I don't see any problem, but if there is one, I'm sure I can find out here.
I ordered a Traxxas Resonator pipe, with the Traxxas aluminum pushrods, and RDlogics Aluminum P2 rockers. I was just curious, could the added power from the pipe with stiffer springs cause the truck to wheelie alot? I would like to stay away from that, as I run mostly on gravel and paved parking lots. Not much offroad bashing for me.
-- Joe
-- Joe
GA
RE: Revo suspension?
although u will see a nice power increase from the pipe, you should have trouble w/ it wheelieing. most people wish it was that easy to make their revo wheelie, i do!
TN
yes i had the same prob....list of things you can do
1.center diff
2.loosing slipper bout 8th turn
3. make rear cvds level and front a little above level
It all worked for me just make sure is you do number dont forget the rear brake kit or you will endo
1.center diff
