tmaxx trans bearing
IN
tmaxx trans bearing
Had to replace the one way bearing for 1st gear. the new one spins both ways on the shaft unless I move the 2 spd gizmo and everything back a little, which doesnt leave enough room for the output yoke to clear the case. The question is, what makes the one way bearing only turn one way? I can't see it. I need to figure out if I got a bad bearing or if I need to get a new shaft also.
Fixed:
I called traxxas and they had me change the primary shaft. that fixed the problem. The rep said any time the one way bearing is changed to change the shaft also.
Fixed:
