Broken again...
Broken again...
Well today I went out with a small crack in the rear upper a-arm. It was my fault in a way but traxxas had the rear camber all messed up. It was way off and I went to screw in the upper pivot to readjust the camber and CRACK! I had no idea it was aready in all the way and I did not torque it dwn that hard but the plastic is really hard? But anyway this was like 2 days ago and I added some CA glue to help hold it together a bit more. The crack was small and only on the top portion of the a-arm but I thought it would hold.
I ran a 2 tanks through it and all was well untill a bad landing from a messed up launch got it just right on the left rear. I head it snap but was able to limp the trcuk back to me. I let it idle the rest of the tank out completing a 1/2 gallon through the engine.
Well it's time to upgrade and I think I want black RPM arms. In addtion to that I want to add a FOC but I really like the reverse and have yet to have any problems with the opti drive system.
Are the gains from just a FOC on a stock revo worth the $14? If they are then I will also add that carbon fiber mount for just the throttle servo..anyone with this combo care to add?
OH
RE: Broken again...
If you're not going to race then I would keep the reverse in it. If you do nothing but bash you will enjoy having reverse more than not having it at all.
GA
RE: Broken again...
ORIGINAL: mrjerryk
PA
RE: Broken again...
ORIGINAL: DaveG55
That's always been my logic. I don't race and like having reverse. Even racing, I wonder if driving skills are not more important than a few ounces saved in weight and the bit of power increase. Seems to me like they would be.
OH
RE: Broken again...
ORIGINAL: rawkfist2
Once the reverse/forward shaft break then put in a FOC
RE: Broken again...
I did the fOC and really didnt see that much of a diffrence. Seems she will hit top speed a little quicker, but not anything to get exited about. I bash mostly and race on occasion, realy just getting into it. I saved all the parts from the conversion and will probably swap it back in befor next run.
I did race a golf cart with a security gaurd today....handed him his ass...LOL!!!
