please help me
please help me
hi i`m a newbie i have a REVO 2.5r and 1 problem i usually drive in street my revo very easy to upturn when i turn left/right in high speed , please help me
RE: please help me
You can lower the suspension by taking off some of the preload tension on the shocks. Also, if you hit the brakes hard before turning you can learn to kind of slide instead of rolling. Stiffer springs and heavier shock fluid might help along with a lower stance.
CA
RE: please help me
do not break and turn at the same time......break before the turn....then give it a little throttle coming out......this will make your revo a little happier....:-)
