Revo moving at idle......
My Revo is moving at idle speed, I tried to udjust idle screw down but no luck. I also ajusted slipper and it did'nt help. Thanks for any help on this.
PA
RE: Revo moving at idle......
Try and adjust the trim on your transmitter this is the easiest way and quickest way to do this. All you have to do is just lower the idle which if the idle screw doesnt do it then you can adjust it by the trim or you can do the throttle linkage as this will also help to lower the idle. But either of those should work, and if they dnt then you clutch spring may be a little on the loose side and may need to be replaced.
IL
I had the same problem a while back. If when you turn your idle screw and it has no effect and your spring isn't damaged you may have an air leak. I had to use gasket seal on my backplate and carb....and haven't had a prob holding a tune since
It was the clutch spring broken. Thanks for the awesome help. I just bought this revo about 3 weeks ago, and it is SO user friendly to work on. I love this thing! I also own a Monster GT and Team Losi Aftershock, and they are no way as easy to work on as the Revo. Thanks again!
