one-way bearing problem PLEASE HELP!!!!!!!!!
well my roller is stuck to the shaft thingy and since i use a pull starter id dosnt come back
i was bashing it with my cousins nitro sport and it cut off then when i tryed to restart it the pull starter wouldnot come back in
RE: ROLLER CLUTCH PLEASE HELP!!!!!!!!!
http://www2.towerhobbies.com/cgi-bin...?&I=LXDDV2&P=M its on the back of the engine its on the backplate thing aka one-way bearing
KS
looks like a one-way bearing? spray some wd-40 inside to see if it will work a bit longer while you get a new one because your old one is worn out? i'm having this problem on an xtm457 myself.
LA
thats called the oneway bearing and when it goes bad it slips never heard of it getting stuck so maybe is your pullstart thats bad the the oneway bearing take it apart and check it out!!
MT
RE: one-way bearing problem PLEASE HELP!!!!!!!!!
that happened to me this weekend as well, some times they just seaze. THey are like $4 so just pick up a new one.
LA
just think for a minute and figure it out its not that hard!!
ORIGINAL: ReVo_BaShEr14
??????????? whats like 4 dollars and i just need to know how 2 get it off
YT, CANADA
Looking at the back of the engine, when you pull the pull start it turns the motor clockwise. Take the pull start off and get an open end wrench that fits the one way bearing, put it on the bearing and turn it counterclockwise while holding the flywheel. If that don't work break out the dremel and cut it off. It is bad anyway.
Good luck.
Good luck.
